Author Topic: 4P Keycode Conflict  (Read 1614 times)
vindic8r
  • Last login:January 10, 2024, 12:36:59 pm
    • MOTUMAME: A Masters of the Universe Arcade Cabinet
4P Keycode Conflict
« on: August 11, 2012, 12:39:16 am »
I've done a bunch of searching and this question seems to have only come up here once long ago, and reading that thread, I'm not sure that I understood the solution.
Default MAME keycodes that are preprogrammed into the IPAC4 have the same controls for P2 buttons 5-8 as P3 directionals. Given that there aren't any 3 player games that use more than 4 buttons, this doesn't seem like it would actually present issues when playing, but it does cause CPWizard to get a bit confused.
My attempts to remap P2 5-8 to different keys have thus far been unsuccessful - comma and period seem available for programming, but for some reason, don't work when I try them in games that I know use them, like Tekken. And CPWizard isn't showing any commands mapped to those keycodes either, so I have to think I'm doing something wrong here.
So I guess I have two questions.
  • What are people using as their keycode mappings on their 4P panels?
  • How does one go about properly setting those mappings in MAME? I've tried doing so from the TAB --> Input (General) --> Player 2 Controls menu, but no matter what I map there, it never works in game. The keycodes I change are always grey (which I hear means they are not the default, so that's fine), but the fact that they don't work, that's not good.
Any thoughts/suggestions would be most appreciated! My MOTUMAME build is stalled until I can crack this nut.  :(
vindic8r
Re: 4P Keycode Conflict
« Reply #1 on: August 13, 2012, 11:59:54 pm »
No ideas? Really?
C'mon guys, help a brother out.
  • Last login:Today at 07:57:50 am
« Reply #2 on: August 14, 2012, 12:53:19 am »
Just to clarify, which is the better way to describe your situation?
1. You can't reprogram your IPac using Ultimarc's WinIPac utility to accept comma and period on P2 Buttons 5 and 6, respectively.
2. You successfully reprogrammed both IPac inputs with comma and period.
You verified they work by using the reprogrammed buttons to "type" in Notepad/Wordpad.
MAME still won't accept changing the default P2 Button 5 and 6 inputs to comma and period.
vindic8r
« Reply #3 on: August 27, 2012, 12:06:54 am »
Actually, Scott, I'm not to the point where I'm programming the IPac just yet. I'm still just updating settings in MAME itself. I'm really just curious what people who have 4P panels with 6+ buttons on P1 & P2 usually map their button presses to. The default for P2 Buttons 5-7 is that they are mapped to I-K-J-L, which are the directionals for P3. This shouldn't present any conflict in game, since there aren't any 4P games that use more than 4 buttons (that I've seen), but I'm a purist and would prefer that each button on the panel maps to a unique key.
I was able to get MAME to accept the following key mappings for P2 and everything tested fine in a quick play of Street Fighter II:
P2 Button 5 = N
P2 Button 5 = ,
P2 Button 6 = .
So I think, assuming that these aren't mapped to some admin function that I've never used, I should be OK.
