Author Topic: WIN XP and a Frontend  (Read 1953 times)
Bobby115
  • Last login:July 18, 2011, 06:55:13 pm
« on: October 07, 2003, 02:24:57 pm »
I have a P4 1.6 running Windows XP PRO. What Front End should I use?? I waould like to have windows XP start and bring up the Front End automaticly. I also will be using a ARCADE VGA card from ultimarc.....
Bobby
Bobby115@aol.com
Cave
  • Last login:June 07, 2009, 10:27:58 am
Re:WIN XP and a Frontend
« Reply #1 on: October 07, 2003, 06:47:41 pm »
Mamewah works well on this setup,Its easy to setup and you can customize it.http://mamewah.mameworld.net/
Bobby115
« Reply #2 on: October 07, 2003, 07:36:00 pm »
what version of MAME do I need to use?? Right now I have MAME32.
« Reply #3 on: October 07, 2003, 07:52:16 pm »
I'd really recommend that you ditch MAME32 in favour of Windows commandline MAME.  There is a great guide to using this at www.mameworld.net/easyemu :)
Edit:  BTW, this site refers to my recommended version as 'Mame Win32' in some parts.
« Last Edit: October 07, 2003, 07:53:20 pm by Minwah »
Bobby115
« Reply #4 on: October 07, 2003, 10:11:39 pm »
Took your advice and got rid of MAME32. I'm using Commandline Mame with MAMEWAH..........
Where do I get the graphics from now?? All the artwork. Its too plain looking for me now :-)
Thanks for the help so far
Bobby
« Reply #5 on: October 08, 2003, 04:51:38 am »
stpfarms
  • Last login:October 08, 2003, 10:47:21 am
« Reply #6 on: October 08, 2003, 10:50:04 am »
I have been playing emulated Roms on my xbox for quite a while now. I am going to make a media center pc though, and was going to play them on my tv with that instead since I could play higher end ROMS.
Is there a FAQ or Tutorial out there explaining the difference between DOS Mame and Mame that runs on Windows XP. I want to know the differences and all that. I take it the command line MAME doesnt run on Windows XP?
I could set up the pc to dual boot if i had to.
Steve
Bobby115
« Reply #7 on: October 08, 2003, 10:54:21 am »
I have the commandline version running on XP, with mamwah running as my front end.
« Reply #8 on: October 08, 2003, 11:06:34 am »
Here are the main MAME's:
DOS MAME - will run under pure DOS, and Windows 98 (probably not XP),
Commandline Windows MAME - will run under Win98/ME/2k/XP.  This is the recommended version for Windows
MAME32 - essentially Windows commandline MAME but with a built in GUI.  OK for a desktop but usually not recommended for a cab
But yes, commandline (Windows) MAME will run under XP - in fact, it is the best version to run unless you have a pretty old machine...
www.mameworld.net/easyemu has some good info on all these versions :)
