Author Topic: Need help with mame and joystick  (Read 1295 times)
pathfndr
  • Last login:September 05, 2014, 11:20:39 pm
« on: August 05, 2012, 05:47:51 pm »
OK i'm running newest mame and mame32. Using 8 way leaf wicos, tried 8 way switch wicos hooked up to ipac2 newest version. Using windows vista this probably is the problem. When playing a game the movement stops when moving and holding the joystick in a direction. Happens in all games. Happens in all directions.  It will go about half way across the screen then stops needs to be pushed again to continue to move and will go a little then stop again and continue. I think this happen like 10 years ago but don't remember the way to fix it. Really weird any info would be appreciated.
  • Last login:Today at 05:35:49 am
Re: Need help with mame and joystick
« Reply #1 on: August 05, 2012, 08:23:25 pm »
Let's start by taking games out of the picture.
1. Launch the WinIPAC application.
2. In panel view, any pressed control icon should light up.
When you press the joystick in a particular direction and hold it, does the associated icon on panel view stay constantly lit or does it shut off like you described?
What about P1 Button 5? (z) If you open a notepad/wordpad window and hold down the button, does it do an unending string of z's or does it do the same thing that you described for the directions?
« Last Edit: August 05, 2012, 08:29:39 pm by PL1 »
pathfndr
« Reply #2 on: August 05, 2012, 09:09:07 pm »
Ok i tested the keyboard hit the arrow keys in game everything works right. I hit the 5 button which is z only did 5 z's then stopped. On winpac arrow lights up then dies wow have no idea thanks for input maybe someone has a a answer.
pathfndr
« Reply #3 on: August 05, 2012, 09:43:23 pm »
Ok thanks all i fixed the problem but really dont like what i had to do. I had my ipac plugged into usb and keyboard plugged into usb, i unplugged all ran ipac thru the old keyboard plug and plugged in old keyboard to the ipac. Thanks
