Author Topic: Anyone tested Analog+ XP with USB Opti-PAC and dual T/B?  (Read 1188 times)
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
« on: October 06, 2003, 04:54:31 am »
Hi,
You might ask "why don't I test it" but to be honest setting up an XP system with Analog+ and dual trackballs would be quite time consuming at the moment. In theory dual trackballs with USB Opti-PAC should work in XP with the new version.
If anyone can confirm this it would be great. Also, if anyone currently has a serial opti-PAC dual trackball setup (with DOS) and wants to try USB with XP, I'll send a USB upgrade kit free of charge.
Thanks,
Andy
u_rebelscum
  • You rebel scum
    • Mame:Analog+
Re:Anyone tested Analog+ XP with USB Opti-PAC and dual T/B?
« Reply #1 on: October 07, 2003, 12:57:00 am »
Confirmed, it works.   :D
On my friend's computer, what was optipac's mouse one was mouse 3 in analog+, and optipac's mouse two was mouse 2.  I.E., the numbering got switched for some reason.  Since you can cange this in Analog+, it's not that bad a problem if it's universal (and not just my friend's system), but something people might want to watch for.
(And thanks for reminding me, Andy; I tested it this last weekend and was going to post, but didn't get around to it. :-\ )
Robin
Knowledge is Power
jerryjanis
  • Last login:July 28, 2026, 05:02:09 pm
  • Skate or Die!!!
    • Jake's Joystick
« Reply #2 on: October 07, 2003, 04:45:19 am »
I tested one serial mouse co-mingling with several usb mice, and that worked fine with Mame Analog+ XP, so the serial Opti-Pac is worth testing, also.
