Author Topic: Star Wars Yoke mounting template  (Read 1804 times)
mytymaus007
« on: July 09, 2012, 03:36:04 pm »
Hey does anyone have a Star Wars Yoke mounting template that you can print out  :cheers:
  • Last login:Yesterday at 01:45:52 pm
Re: Star Wars Yoke mounting template
« Reply #1 on: July 09, 2012, 03:43:49 pm »
Here you go, MM.
mytymaus007
« Reply #2 on: July 09, 2012, 05:37:00 pm »
Nice your the man thanks for quick reply :cheers:
Gray_Area
  • -Banned-
  • -Banned-
« Reply #3 on: July 09, 2012, 09:07:57 pm »
Just measure the distance from center to one stud, draw your line, then rotate 90s degrees three times. Or measure between two diagonal posts, draw your line, then rotate 90 degrees. Or, like I did, measure between length and width between posts - it's 4.5 inches - and mark your target accordingly. Or, you could put the yoke on the target, and mark around the studs, then drill.
-Banned-
