Author Topic: SATA to USB adapter not detecting hard drive  (Read 4570 times)
vanrose72
  • Last login:November 24, 2025, 12:30:51 pm
« on: June 27, 2012, 09:01:45 pm »
I have a SATA hard drive that crapped out on me recently. I replaced the drive and also got a SATA to USB adapter so I can try (with fingers crossed) to retrieve what data I can.
The old drive isn't being detected via USB, even after 24 hours chilling in the deep freeze.
The initial issue with the drive was that it wasn't detected at startup, so I guess it's just continuing its previous behavior.
I'm wondering if there's a trick to getting it detected or if I'm just wasting my time on a completely busted hard drive.
Anyone have any ideas?
404
Re: SATA to USB adapter not detecting hard drive
« Reply #1 on: June 27, 2012, 09:20:07 pm »
does the drive spin up at all? any ticking noises? chances are the controller board is fried. your only chance would be to get a controller board from another, exact model drive and swap them out temporarily.
vanrose72
« Reply #2 on: June 27, 2012, 09:22:05 pm »
Yep, the platters are definitely spinning. Maybe a new controller board is the ticket.
404
« Reply #3 on: June 27, 2012, 09:51:41 pm »
what model is the drive?
vanrose72
« Reply #4 on: June 28, 2012, 08:15:34 am »
It is a Seagate 7200.11. The physical operation of the drive sounds completely normal, like the initial click when it starts spinning as well as the vibrations as it continues.
« Reply #5 on: June 28, 2012, 08:28:50 am »
have you tried a different USB port? my SATA to USB is finicky, thats why I ask.
vanrose72
« Reply #6 on: June 28, 2012, 12:28:09 pm »
I've tried multiple USB ports in both the front and back of my machine, but none of them will detect the drive.
I'm still thinking the controller board is the culprit. Besides that, I could only imagine a shoddy USB adapter as the source of my issue.
ed12
« Reply #7 on: June 28, 2012, 01:14:03 pm »
hi
i use a proggie called easeus partition recovery 5.0.1
it's freeware
with it u can tell if u can repair the drive or not
in winblow's if the mbr is not there winblow's will not asign it
with this proggie u can c it even if the mbr is bad
if the controller board is bad
u could poke around to find a drive that u can salvage the control board off
of
ed
vanrose72
« Reply #8 on: June 28, 2012, 03:30:06 pm »
hi
it's freeware
of
ed
Thanks for the info, ed. I will most definitely check that out as soon as possible. Sounds great for troubleshooting stuff like this!
vanrose72
« Reply #9 on: July 23, 2012, 08:16:32 am »
I finally got to the bottom of my issue. My problem was the result of buggy firmware on the hard drive.
I contacted Seagate after researching an existing firmware issue prevalent among other hard drives like mine. The company agreed to flash the firmware free of charge, which completely resolved the issue at no cost to me.
