Author Topic: Makvision 25" tri-mode (automatic) power up?  (Read 2104 times)
emuola
  • Last login:June 15, 2017, 02:19:54 am
« on: June 26, 2012, 10:47:02 am »
Planning to get that monitor for my Mame cab :) Video signal is a piece of cake, but I cannot find info on how the monitor is turned on? Some auto-sensing stuff? My cab has a power switch, which is wired to the mobo of my pc in the front. Something similar for the monitor, maybe?
MonMotha
Re: Makvision 25" tri-mode (automatic) power up?
« Reply #1 on: June 26, 2012, 01:34:41 pm »
In general, arcade monitors are on whenever power is applied to them.  There is no need to "turn them on".  Just apply power.
emuola
« Reply #2 on: June 26, 2012, 01:53:19 pm »
Thanks MonMotha :) Ok, I presume it would be wise to have an option to turn it actually off, when not in use? It's pretty easy to make a switch in the middle of the power cord and place it somewhere near the power switch for the pc :)
ed12
« Reply #3 on: June 26, 2012, 01:56:43 pm »
hi
if u turn the cab off via
Planning to get that monitor for my Mame cab  Video signal is a piece of cake, but I cannot find info on how the monitor is turned on? Some auto-sensing stuff? My cab has a power switch, which is wired to the mobo of my pc in the front. Something similar for the monitor, maybe?
then it should kill the power to the monitor
ed
emuola
« Reply #4 on: June 26, 2012, 04:12:00 pm »
hi
ed
Ok, thanks for the info ed :)
