Author Topic: Queston on mouse hack with 4 pin receiver...  (Read 1209 times)
gndprx
  • Last login:September 08, 2014, 11:25:49 am
  • nope...
« on: October 03, 2003, 01:59:08 pm »
Okay, all of the tutorials around only describe 3 pin receivers for the pickups.  I have a bunch of old compaq and dell mice that have a very small footprint logitech board in them (1 1/2" x 1 3/4" maybe).  However all of them have 4 pin receivers.
Any ideas on what the 4th pin may be?
zero-one
  • Last login:December 17, 2003, 10:30:04 pm
  • Still learning...
Re:Queston on mouse hack with 4 pin receiver...
« Reply #1 on: October 03, 2003, 04:43:23 pm »
Hi.
Sorry I can't help but I feel your pain. Most of the mice I've accumated over the past 10 years were of the logitech variety and have 4 pins per receiver. I didn't even try hacking them. Only a very old IBM mouse was suitable to hack. I was not about to go buy another mouse.
All I can say is that Logitech must have made more mice than any other company. They're everywhere!  ;D
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #2 on: October 03, 2003, 05:57:10 pm »
I hacked a 4 pin compusa mouse.
Here's a pic, I will explain as best I can.
http://www.fe.donkeyfly.com/images/mouse1.jpg
First off it is a cheap mouse!  Noticed I tried soldering to where the IR receivers where.  The top layer of the electronics came off.  So I followed the circuits back tot he chip and soldered to the chip.
A red and green wire represent a pair that go to the trackball.  The ground on the reciever is faily obvious so oyu don't need to worry about that.  What I did then was make leads with quick disconnects to each of 3 pins from both receivers (actually leads came from the controller chip where the receiver circuits went to).  Then it was trial and error.  Make sure you unplug the mouse before you change wires around.
5v and ground I got form the USB's 5v and ground on the mouse.
