Author Topic: AMI Rowe CD100F Select and Reject Problems  (Read 3189 times)
jball1954
  • Newbie
  • Last login:June 17, 2012, 03:15:31 pm
« on: June 17, 2012, 12:32:28 pm »
My Cd100F juke rejects some songs about a minute or so into a track. It seems to do better the more selections I play, though. Also, quite often, I have to select about 20 selections before it will start to select anything. After that, it starts to work fine. I've not swapped out the CCC but thought maybe that was the problem. Any suggestions?
jdemarti
  • Last login:May 31, 2022, 10:57:25 am
Re: AMI Rowe CD100F Select and Reject Problems
« Reply #1 on: June 22, 2012, 09:45:56 pm »
Interesting situation.  Couple different ways to go on troubleshooting.
First, Does the cd seem to skip at all before reject?  When you make the selections, does the cd get put in the player then reject the disk?  If it does, what happens with the cd?  Does it spin at all?  make quarter turns, etc?  If it is any of those then the optical assembly may be going bad.
If it is something else, I may lean towards looking into the CD mechanism control or the ccc.
