Author Topic: LED Wiz Problem  (Read 1678 times)
Chappie
  • Last login:February 04, 2023, 07:55:59 am
LED Wiz Problem
« on: June 17, 2012, 06:45:03 am »
I am having a problem with my LED Wiz. Finally got around to installing it and can't get the banks to distribute the power. I put 12V on bank 1-8, 9-16 and 17-24 and it measures at 11.97V at each screw but no lights. I remove the 12V wire and touch it to each port screw (1-24) and it lights that light up, so I have to think the wires are run correctly. I have a RGB trackball on bank 25-32 at 5V and that tests properly by using 5V USB. Any thoughts.
Steve
« Last Edit: June 17, 2012, 09:07:38 am by Chappie »
BobA
  • What Me Worry?
Re: LED Wiz Problem
« Reply #1 on: June 17, 2012, 11:15:06 pm »
The led wiz has very specific wiring needs when providing power to different banks.  The terninals provide a ground to power the LED.  The LEDs have a common power lead which in your case would be 12V.   The fact that you touched the 12V power lead to each terminal and the LED lights up leads me to believe that you have the LEDs wired backwards.   The ground wire touched to a terminal should light up a properly wired LED and not the power lead.
There is a diagram of proper wiring on GGGs site.   If you are still having problems send an email to Randy.
Chappie
Re: LED Wiz Problem
« Reply #2 on: June 18, 2012, 07:14:36 am »
Baffling...I took 5 buttons on the same bank (17-24) and reversed the wires on the buttons and isolated them from all other buttons/grounds and checked that I had 12V at the 17-24 bank and tried again with no luck. These are single light LEDs from paradise. Were there rumors that Paradise Arcade LEDs and LED Wiz did not get along well together?
Steve
RandyT
  • Last login:June 24, 2026, 02:15:54 pm
    • GroovyGameGear.com
Re: LED Wiz Problem
« Reply #3 on: June 18, 2012, 11:48:11 am »
Sounds like something is not wired properly.  I sent you an email with a request for a photo of how it is currently wired, so I can help you figure this out.
RandyT
