Author Topic: Mame INP recording question  (Read 3458 times)
(+_+)
  • Let me splain.
  • Last login:July 27, 2012, 09:00:32 pm
  • For I am ]{eyser Soze
« on: June 13, 2012, 11:33:43 am »
Hi All,
Does anyone know if Mame stops recording when pause is used or if there is an upper limit to the recording time. I was playing
Robotron on difficulty 10 and rolled the score. When I played the recorded inp file, the score stops at about 831,000 points.  :'(
The file size ended up as 4,026 KB which looks small seeing the game must have lasted about 2 hours.
Any ideas?
Marc
This plan is so perfect, it's retarded. -- Peter Family Guy
CrazyKongFan
  • Last login:June 06, 2017, 01:22:29 pm
Re: Mame INP recording question
« Reply #1 on: June 14, 2012, 10:03:01 pm »
Not sure which version you're using, but I know on the Wolfmame versions, the pause button is disabled when you're recording. There shouldn't be any upper limit (well, maybe if you run out of hard drive space). The top score for one of the Nibbler versions over at MARP took 25 hours using Wolfmame 106.
(+_+)
  • Let me splain.
« Reply #2 on: June 15, 2012, 05:33:07 pm »
Thanks for the info CrazyKongFan.
I did some experimenting and it looks as though the pause in mame .145 throws off the recording every time I tried it.
I'll have to find larger blocks of free time.
1500points
  • Last login:November 20, 2018, 01:44:12 pm
    • How to succeed at Robotron
« Reply #3 on: November 12, 2012, 02:30:35 pm »
anyone seen Master Marc.... (+_+) ??????
