Author Topic: What size T-molding do I need?  (Read 3276 times)
rmusick
  • Last login:November 12, 2017, 09:15:41 pm
« on: June 04, 2012, 02:41:53 pm »
Hey can someone help me out here.  I am trying to place my orders today for some parts,  I am going to order some laminate for a cabinet (was going to paint, but that is one skill i dont have, tried this weekend and it looked like crap.) I will need to order 2 types, one just a stander 3/4 laminate but the other has to be enough to cover 3/4 plus Formica on both sides.  can anyone help?
BobA
  • What Me Worry?
Re: What size T-molding do I need?
« Reply #1 on: June 04, 2012, 06:02:13 pm »
Depends on the thickness of the material that you are making your cab out of.
rmusick
« Reply #2 on: June 05, 2012, 07:55:44 am »
DOH!!! sorry left that out.. Its 3/4 lumber, standard black Formica.
CoryBee
  • Bopity Boopy
« Reply #3 on: June 06, 2012, 09:08:16 pm »
Then if I am not mistaken, http://www.t-molding.com/store/home.php , get the 3/4" t-molding.  :banghead:
phyrosis
  • Last login:June 20, 2012, 06:54:07 pm
« Reply #4 on: June 07, 2012, 12:03:59 am »
at the site that corydee linked they have T molding that is 13/16" this is a slightly larger Tmold that the 3/4 that some of your cab is going to need like corey said, i am willing to bet that the 13/16th of an inch is going to be good enough for your 3/4inch and formica. considering i have no clue how thick standard fomica is, that is the best i can do for ya.
if you have a caliper that is capable of inside and outside dimension you can find the exact thickness you will need.
rmusick
« Reply #5 on: June 07, 2012, 08:08:39 am »
Thanks, I went ahead and ordered the Formica,  As you said unsure of the thickness i have seen it thin and i have seen it thick.  Ill get one of those calipers and check when I get it all applied
Mental
  • Last login:May 18, 2013, 09:46:08 am
    • Complete cocktail arcade system
« Reply #6 on: June 07, 2012, 09:16:43 am »
T-Molding.com sells 13/16" for this purpose. Buy it instead of the 3/4". Works perfect.
Complete cocktail arcade system: arcadecabinets.ca
rmusick
« Reply #7 on: June 07, 2012, 09:34:17 am »
Thanks checking them out now.
