Author Topic: Painting my cab. A quick question.  (Read 2157 times)
RedSquirrel
  • Last login:September 18, 2003, 12:07:55 pm
« on: October 01, 2003, 06:43:22 pm »
In the process of painting my cab (well some of its drying since its 11:40pm here) but even though i painted it equally the same, some parts are darker and some lighter. Kinda looks like the paint hasnt dried yet, but if you touch it , its not wet.
Or is it because it hasnt fully dried yet? The paint says 3 hours to dry, although im hoping by tommorrow morning it will all look the same all over.
thx..
zero-one
  • Last login:December 17, 2003, 10:30:04 pm
  • Still learning...
Re:Painting my cab. A quick question.
« Reply #1 on: October 01, 2003, 06:47:35 pm »
You may need to give it another coat before it looks even. Some stops will absorb more paint than other spots.
Did you use a primer first?
RedSquirrel
« Reply #2 on: October 01, 2003, 07:09:08 pm »
its the third coat, so i wouldnt have expected it to need anymore.
And nope, didnt prime. It really didnt seem to do much when i did my control panel, so i skipped it this time.. was that a good or bad thing? i dont know.
I suppose i can always prime it tommorrow if it looks the same.
Safron
  • Last login:September 27, 2004, 12:00:41 am
« Reply #3 on: October 01, 2003, 08:52:17 pm »
Not priming killed you.
Always prime the surface, it really makes the paint job look 900% better (and you use less paint)!
Ghoul
  • Last login:September 15, 2004, 08:59:06 am
  • Karate Fish Master
« Reply #4 on: October 01, 2003, 09:29:51 pm »
If you decide to prime it you might do a little sanding if it's uneven.
Frostillicus
  • Arcade Artist
  • Last login:April 18, 2023, 07:36:29 am
    • My MAME cabinet site
« Reply #5 on: October 01, 2003, 10:34:14 pm »
The important thing to ask is what material are you using? MDF? Wood? Other?
paigeoliver
  • Awesome face!
« Reply #6 on: October 02, 2003, 12:47:51 am »
Also, how are you painting it? Spray can, brush, or roller?
I did a Defender once (red) with spray cans, and it took around 40 coats. Although it did come out looking really sharp (why I traded that nice looking cab for an Ipac and a Jamma board I will never know).
RedSquirrel
« Reply #7 on: October 02, 2003, 04:39:47 am »
using mdf and painting with a roller.
Anyway its morning now., and i just checked and it seems the same. Might sand down and primer.
