Author Topic: ipac 4 issue  (Read 2439 times)
nateious
  • Last login:February 11, 2014, 02:39:51 pm
ipac 4 issue
« on: May 11, 2012, 08:23:26 pm »
Hi all, I think I may have a problem with my new ipac-4.  What happens when is when I hook up my control panel buttons to the ipac the default button set does not line up with what it should be.  For example moving the p1 joystick  up down left right instead of pushing the up / down / left / right keys but instead hits z x shift space.  I read up on the interactive programing and text mode functionality and hit control alt p to bring up the menu.  I then did a reset to default to see if that would fix the issue.  It did not, so I hit L to list the current config.  This is what showed.  I had seen forum posts about some people getting the ipac 4 shipped out with the ipac-2 firmware.  Since mine is only showing 2 players worth of controls I wonder if this might be what has happened.
Unfortunately I've also read that you need the USB plug to update the firmware and I only have the PS2 one.  Is there any way around this?
Code: [Select]
*** i-pac interactive programming and test mode ***
    t for button test mode
    l to list current config
    e to save and exit
    a to abort
    or press switch you want to program
 1 right = rght   tab
 1 left = left   entr
 1 up = up     `
 1 down = down   p
 1 sw 1 = lctl   5
 1 sw 2 = lalt
 1 sw 3 = spce
 1 sw 4 = lshf
 1 sw 5 = z
 1 sw 6 = x
 1 sw 7 = c
 1 sw 8 = v
 1 coin = 5
 1 start = 1      1
 1 a = p
 1 b = entr
 2 right = g
 2 left = d
 2 up = r
 2 down = f
 2 sw 1 = a
 2 sw 2 = s
 2 sw 3 = q
 2 sw 4 = w
 2 sw 5 = i
 2 sw 6 = k
 2 sw 7 = j
 2 sw 8 = l
 2 coin = 6
 2 start = 2      esc
 2 a = tab
 2 b = esc
done
    press next switch or e to exit
e
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
Re: ipac 4 issue
« Reply #1 on: May 14, 2012, 11:06:29 am »
Can you send me an email, if not done so already, and I am sure we can address this.
andy@ultimarc.com
nateious
Re: ipac 4 issue
« Reply #2 on: May 15, 2012, 12:27:45 pm »
You actually already did, I just wasn't sure how to delete the thread and didn't want to double post.  Thanks for the quick turn around time!
andy@ultimarc.com
lanman31337
  • Last login:January 10, 2024, 10:36:50 am
  • set to ludacris speed!
Re: ipac 4 issue
« Reply #3 on: May 15, 2012, 04:08:32 pm »
What was the solution?
