Author Topic: Configuring U360 joystick?  (Read 2318 times)
P-chan
  • Last login:April 13, 2022, 12:39:40 am
« on: May 05, 2012, 01:56:46 am »
Ok, so I got my control panel all wired up, I have joystick #1 and #2 assigned different ID's as per the directions on the Ultimarc site.  However, I have a few issues/questions:
1)  How do I re-map the joystick to recognize the correct directions?  Obviously I could unscrew the circuit board and rotate it, but for instance, my joystick #1 shows up as moving left when it should be pointing down.
2) How do I tell the joystick there is an octagonal restrictor installed?  The Ultimarc site says that there is an option for it in the UltraMap software, but this is what I have:
3) How do I configure a front end (or MAME itself) to automatically load maps upon game selection?  For instance, if I select "Galaga" the joystick should recognize that it needs to be in 2-way mode, or 4-way mode for pac-man, for instance.  I can tell on this page : http://ultimarc.com/ultrastik_prog.html  how do possibly do it with MAMEwah, but what about other frontends?
Thanks everyone!
Also, I would suggest getting some Windows 7 instructions /screenshots up there, things are a little different in the control panel than they were 10 years ago :)
P-chan
Re: Configuring U360 joystick?
« Reply #1 on: May 06, 2012, 08:37:44 am »
Bump. 25 views and 0 replies? :(
bbee383
  • Last login:October 26, 2015, 06:29:59 pm
« Reply #2 on: May 06, 2012, 01:08:21 pm »
1) Easy way is to rotate the board....Its only 4 screws.
2) I believe the Circular is the same at octagon.
3) LEDblinky can take care of this. You do not need to have any LED's. The software has a check box to use the u360's and it will load the right maps in you frontend.
Hope that helps.
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
« Reply #3 on: May 06, 2012, 01:18:01 pm »
Note you can check the board is the right way as it has "Top" marked on it.
But you can rotate the faceplate also. It might be easier. 4 screws on the front of the plate.
Andy
P-chan
« Reply #4 on: May 06, 2012, 11:50:59 pm »
Thanks bbee383!  I guess you're right, it's only 4 screws, lol.
I will check out LEDBlinky, thanks for the suggestion!
« Last Edit: May 06, 2012, 11:54:28 pm by P-chan »
P-chan
« Reply #5 on: May 06, 2012, 11:55:03 pm »
Andy
And the octagon restrictor?  How do I set that in the software?  You obviously saw the screenshot....?
AndyWarne
    • Ultimarc
« Reply #6 on: May 07, 2012, 03:35:27 am »
Andy
The circular restrictor should be selected.
Andy
