Author Topic: How do I know my V-size setting is correct or if it's the res that has to change  (Read 1256 times)
dave197878
  • Last login:May 03, 2012, 12:30:19 pm
I Have a CGA 25" monitor, Arcade Vga 3000, mame 0.144
And I have used M.A.M.E. Resolution Tool to create the ini files.
For the most games the res is perfect for some close and others like, frogger they seem totally off.
I used the M.A.M.E. Resolution instructions to weed out some unusable  resolutions for my standard arcade monitor.
How do I know my V-size setting is correct .. for example on games like final fight there's a little black border on top and bottom but for mortal kombat games it's perfect.
So do I find one game then set V-size and change res for other games? whats the best way?
« Last Edit: May 02, 2012, 11:38:02 pm by dave197878 »
dave197878
Re:
« Reply #1 on: May 02, 2012, 06:33:50 pm »
More resolution issues.. It was suggested on this board to use 640X240 for pacman but the top and bottom get cliped off.. I tried every res in M.A.M.E. Resolution Tool with no luck.. any suggestions?
« Last Edit: May 02, 2012, 11:41:47 pm by dave197878 »
