Author Topic: SNES to Arcade Monitor  (Read 5740 times)
starwarsfan54321
  • Last login:October 26, 2017, 04:40:26 pm
« on: April 30, 2012, 09:24:29 pm »
Okay, I am currently working on my first cab, so far, I have a multiboard installed and am really enjoying, next on my agenda is to add artwork and a new lcd monitor from here, over the weekend, I rediscovered my SNES in a closet with all of my games, controllers and composite cable, is there anyway to convert the composite cable to either CGA or VGA?
knohbody
  • Last login:January 31, 2019, 11:49:53 pm
Re: SNES to Arcade Monitor
« Reply #1 on: April 30, 2012, 09:59:42 pm »
The SNES can output RGB. http://gamesx.com/wiki/doku.php?id=av:nintendomultiav should have all the info you need if you want to wire it directly. Easiest way would be to find a rgb scart cable.
I think the SNES 2 (newer, smaller version) doesn't do RGB, but there's a mod linked to on the bottom of the gamesx link above.
VGA is possible with a converter, but you'll still need the RGB mod.
starwarsfan54321
« Reply #2 on: April 30, 2012, 10:52:23 pm »
I have the original version, so could I just get a composite vga converter?
Justin Z
  • Last login:December 18, 2025, 09:47:41 am
« Reply #3 on: April 30, 2012, 11:00:40 pm »
The thing about using a composite cable and converting that signal is that it is going to look like hell.  So if you can avoid it, do so.
BurgerKingDiamond
« Reply #4 on: May 01, 2012, 08:02:34 am »
you can't convert composite to RGB.
you need to get a SCART cable. You can hack that to work with your arcade monitor or you can buy this
http://etim.net.au/scart2arcV20/scart2arc2.htm
-Welcome to the Fantasy Zone.
elkameleon
« Reply #5 on: May 01, 2012, 10:03:38 am »
I used to have a SNES store display unit, that used a professional display, was hooked up through SCART, of course I was like 12-13 when I was tinkering with it, I had no idea what SCART was then. :P Bet let me tell you, that thing had a beautiful picture!
Justin Z
« Reply #6 on: May 01, 2012, 12:16:14 pm »
That's not entirely accurate.  You can't pass through composite to RGB, but you can absolutely buy a converter box that will take a composite signal and "translate" it to RGB.  As I mentioned, though, it will look awful.
BurgerKingDiamond
« Reply #7 on: May 02, 2012, 08:41:56 am »
I'll rephrase. You can't convert composite to RGB without it looking like crap and completely negating the purpose of the conversion in the first place.
get a SCART cable.
starwarsfan54321
« Reply #8 on: May 26, 2012, 10:33:16 am »
Okay, if I get a scart cable, how do I use that as input for an arcade monitor and would this work for other nintendo systems like the N64 and gamecube and will a scart cable for the gamecube work with a snes?
elkameleon
« Reply #9 on: May 27, 2012, 12:00:50 pm »
N64 doesnt output RGB natively, i've tried it with that same scart cable I had for the SNES, it just comes out black and white. Not sure about the gamecube though.
boardjunkie
  • Last login:March 05, 2019, 06:05:58 pm
« Reply #10 on: May 27, 2012, 11:44:06 pm »
Most of the laserdisc games used a composite-> RGB board made by wells Gardner.
http://forum.arcadecontrols.com/index.php?topic=88697.0
That guy right there. I have a few but never bothered to check out the image quality. They were just leftovers from scrapped games....
