Author Topic: Romlister Invalid input file. Unable to locate MAME or controls.xml header!?  (Read 3783 times)
Turambar
  • And I don't watch Fox news or use Happ joysticks.
  • Last login:October 03, 2021, 11:10:13 pm
  • Owner of Wayback's Arcade
    • Wayback's Arcade
A search revealed that a few people had this problem with romlister, but I was wondering if anyone had a work around or an alternate program.
NOP
  • Last login:September 19, 2017, 08:22:27 pm
  • I stole my avatar.
    • winterMAME
You contacted me directly about this, but I haven't heard back yet.
In case anyone else stumbles across this, so far the problem appears to be that the mame xml file never got generated at all.  The xml file you attempted to attach and send to me was 0 bytes in length, so there isn't anything to work with.
In the next romlister update, I'll add a check to see if the -listxml command failed, and if so pop up some kind of warning box.  I'm not exactly sure WHY that might fail, but that's our only lead so far...  stay tuned mystery fans!
Yenome
  • Last login:November 14, 2025, 04:36:28 am
  • Punch a fish. Make a wish
Ive had bad xml files made when a 3rd party program called the command for it (maximus arcade) if there wasnt enough memory it would stop making the XML. I ended up having to make the xml on my quad core and copy it over. but that was before i upgrade the cab to a dual core.
