Author Topic: Hiding xp for standalone jukebox  (Read 3461 times)
ronnie-dent
  • Last login:May 15, 2020, 09:42:50 am
« on: March 26, 2012, 10:49:57 am »
Hi does anyone know of a tutorial on how to have xp running say album player, and that can be just unplugged without shutting down the os, would love to have this option and not see any xp, what to use tiny xp, xp embedded, instantsheller I have no clue where to start
thanks for any advice
Ronnie
Re: Hiding xp for standalone jukebox
« Reply #1 on: March 26, 2012, 11:09:31 am »
This WIKI page is a good place to start
http://wiki.arcadecontrols.com/wiki/Hiding_Windows
Generally, you won't want to just "power off" a windows PC. AP Probably would be ok (assuming it wasn't in the middle of a scan with it's DB open and being written too) but XP itself will often have cache files, etc open and being actively written to.
If possible, set the POWER BUTTON to "shutdown" in the XP Power options. This will effectively perform a "shutdown" when you hold down the power button for a second or two.
The only problem with it I've seen is if you hold down for too long, you'll get a hard power off, which you usually don't want.
Alternately, you can launch AP with a bat file, and just waits till AP terminates (ie user closes AP) at which point the next command in the bat file is a shutdown command (there are tons of command line apps out there that can start a shutdown from a bat file.
IF you REALLY want to be able to just "unplug the damn thing  :) ", first, I'd turn off the paging file. Then, I'd probably look into the "kiosk mode" file system driver. Someone here on the boards mentioned that it's available with the Embedded XP dev kit. Basically, once you turn it ON, it effectively make the harddrive "readonly" and all HD mods go to a "ram disk" which is lost when you reset.
But that way, you can't possibly hose your XP install on the HD.
The only drawback is things like saving playlists you might make, that sort of thing....
ronnie-dent
« Reply #2 on: March 26, 2012, 11:25:26 am »
Thanks for taking the time to reply, will have a read through that, in my minds eye I want a coin op unit that will be like a comercial machine, that's how I have all my games pinball fruit machines etc, then should I decide to sell it's not personalised to me apart from the music lol
thanks Ronnie
