Author Topic: Help with Noisy Monitor  (Read 1545 times)
sadstate
  • Last login:October 23, 2013, 11:27:35 pm
« on: March 25, 2012, 01:44:34 pm »
I'm very new to any sort of electrical wiring and ran into a problem while trying to convert an old cabinet to MAME. I think the original power setup was wired incorrectly. Power went from the wall to the power switch, from the power switch to a fuse, from the fuse to a power supply. The power supply split power to the circuit board, a few lights, and the monitor. There was a transformer sitting in the cabinet, but it was not connected in the circuit at all, so power was going straight from the power supply to the monitor.
I pulled out the circuit board, disconnected the lights, pulled out the power supply, and put the transformer back into the circuit. So now power goes to the switch, then to the fuse, then to the transformer, and then to the monitor. I think that is right, but like I said, I'm very new to this.
Well, the monitor seems to power on and off, but some part is producing a loud hum/buzz and lots some crackling. that sound wasn't happening before I redid the wiring. It looks like the monitor has a model number of 25k7107 (though there are a few other number sequences on the monitor too). The transformer looks really old so maybe it could be a problem but it don't know if that's the kind of thing that could be humming.
I've attached a couple pictures. One shows the monitor and the other shows the power wiring through the transformer.
So, I'm trying to figure out if I've got the wiring correct and how to get rid of the noise. Thanks for any help.
sadstate
Re: Help with Noisy Monitor
« Reply #1 on: April 04, 2012, 03:33:36 pm »
Ok, I think things are working pretty well now. I'd like things to look a little better though. I've attached a picture of the screen display as an example.  As you can see, there are two issues 1) the vertical positioning is a bit high and 2) there is a pincushion effect going on.
As setup, I still have the 25k7107 monitor. My computer is using an ATI Radeon 7500 with cataclysm  6.5. I've got soft15 installed. Its running at 640x480 through the jpac.
For 1) I've twisted the V-position pot of the monitor to lower the display as far as it will go. I've also gone in to cataclysm and adjusted the display position down as far as I could through its display position interface.
For 2) I've just messed with height and width pots on the monitor to try to make it less noticeable. I don't see a pincushion pot anywhere.
Any thoughts would be appreciated.
