Author Topic: Has anyone made thair own heat bender?.  (Read 2409 times)
rockyrocket
« on: March 22, 2012, 03:53:06 pm »
So I do like to bend plexi for projects now and again and usually just clamp two straight edges to the piece then go at it with a heat gun.
But memories of the proper heat bender we had at school make me Wonder if any of you have made one?.
I have heard tales of people making them by removing the element from hair dryers but wonder if there is a more elegant solution?.
GregD
  • Last login:December 23, 2025, 04:38:08 pm
    • Arcade Nebula
Re: Has anyone made thair own heat bender?.
« Reply #1 on: March 22, 2012, 04:24:35 pm »
Here is a link to the bending strip heating element sold by Tapp Plastics.  They also include plans to make your own bender.
http://www.tapplastics.com/shop/product.php?pid=169&
« Reply #2 on: March 22, 2012, 05:07:44 pm »
75 bucks though....jeez, kinda breaks the bank for a socket plug wired to a strip of metal mesh.  :o
I think they are pretty cheap to make, here is one made from a toaster element.
http://www.sculpturegifts.com/pm/sculpture/plex_bender.html
rockyrocket
« Reply #3 on: March 22, 2012, 05:17:43 pm »
Both good food for thought, this is what i saw
rockyrocket
« Reply #4 on: March 22, 2012, 05:19:11 pm »
really just want something from here..
http://www.awltech.co.uk/heat_benders.php
SavannahLion
« Reply #5 on: March 22, 2012, 06:31:03 pm »
I toyed with it for a long time. Even have a couple of old wire-type heaters I might use (though I might repair them too. It's colder than a witches titty in the garage). I also experimented with heat bending PVC pipe too.
So far, I've been doing the same as you and using a heat gun for that. It's tolerable but it's tough to make professional looking tight bends.
I'm kind of torn between a vacuum forming rig or a heat bending rig, I only have enough heat elemnts for one really.
bkenobi
« Reply #6 on: March 23, 2012, 01:47:03 pm »
I don't have a use for either, but the vacuum former looks like it would be really fun to play with.  Maybe I should convince my wife that we could make fancy chocolates for gifts or something.   :cheers:
rockyrocket
« Reply #7 on: March 23, 2012, 02:02:50 pm »
Careful you were almost a man stating there was a tool he never needed!, saved it at the end though :).
think at some point I will make one, maybe hinged with an angle finder attached.
Just need to go buy a toaster now and wait for it to break.
« Reply #8 on: March 23, 2012, 02:54:51 pm »
Just check out your local thrift store, or recycling center. I'm sure you can find an old one for like $5
