Author Topic: Visual Pinball - a couple of questions  (Read 1980 times)
monkey puzzle
  • Last login:March 23, 2024, 02:11:59 pm
« on: March 18, 2012, 07:21:57 pm »
I've just installed Visual pinball in my cab (8.1). I have a couple of problems I cant find the answer to.
1/ When I launch vp (from Mala) the mouse pointer is visible in the centre of the screen. Is this normal, and is there an easy way to stop this?
2/ With some of the older tables I can add credits and operate flippers, but when I press start the ball does not appear.
3/ When you launch some of the tables (such as Adams Family) a window pops up allowing you to select country etc. Is there a way to stop this popping up every time?
BobA
  • What Me Worry?
Re: Visual Pinball - a couple of questions
« Reply #1 on: March 19, 2012, 12:40:33 am »
Some older tables have a separate button to raise the ball into the chute.
I dont get that screen but I am using VP 9
  • Last login:March 28, 2026, 02:54:37 pm
« Reply #2 on: March 19, 2012, 01:26:22 am »
I'll be you went to the "official" visual pinball website right?  That thing has been dead for years.  The most current version of vp is 9.12.  The difference between 8 and 9 and the tables made in 8 and 9 is like night and day.  All of the problems you just mentioned will go away if you upgrade to 9.  The vp 9 megapins, for example, have a checkbox that you can click to quit asking you which rom to use.  ;)
Go to vpforums.org and get setup there.
As for the mouse pointer, my wrapper or any of the vp wrappers/launchers will take care of that, but once you press a key it goes away anyway.
monkey puzzle
« Reply #3 on: March 19, 2012, 05:47:50 pm »
2/   Solved - Thanks BobA  :applaud:
3/   Solved - I just realised that there is a tick box to "Hide menu on startup". Doh.
1/   The mouse pointer does dissapear when you press any button. I guess I can live with this is there is no easy fix.
ark_ader
  • I glow in the dark.
« Reply #4 on: March 22, 2012, 06:14:12 pm »
Your wrapper needs updating, for the eleventy'th time...
monkey puzzle
« Reply #5 on: March 23, 2012, 07:16:25 pm »
Ok, which wrapper do you suggest I use?
