Author Topic: does anyones have a "sinfo11"program to see the ..  (Read 4451 times)
tommycoins98
« on: June 03, 2002, 09:31:52 pm »
hi folks some body has been use  the sinfo program to know which control type use each mame game,
I have this program, but when i generate a listinfo .txt the program only display 10 games, some body have a file.txt ready for put in the program or a file caver.ini
this program its very affortable to plane and dessing your control panel please check this link(SortInfo 1.1)
http://hem.passagen.se/robert.palmqvist/index.html
if some body have the file ready to use with this (caver.file)program with all game list please sende me to my email
Tiger-Heli
    • Tiger-Heli
Re: does anyones have a "sinfo11"program to see th
« Reply #1 on: June 04, 2002, 04:52:40 am »
SortInfo is a great little proggy, but I don't know that it's been updated since winMAME became the standard build.
I usually end up running it from a listinfo file as follows (from the Sinfo documentation):
"If you can't import from MAME then make a listinfo file by running MAME with the following command line: "MAME -listinfo > listinfo.txt". MAME should then make a file named "listinfo.txt" and that one can be imported as a "List Info File"."
Once you build the file, you select "File - Import - ListInfo file" and then tell the program where the file is located.
Post a followup if this fails, and I will see if I can suggest anything else.
