Author Topic: Pacman help  (Read 3037 times)
urgeboy
  • Last login:June 05, 2012, 12:27:40 pm
Pacman help
« on: March 09, 2012, 06:18:02 am »
So I found a pacman on craigslist. The person said the game had an issue with "the board not coming up". When I asked if it was playing blind (and described what that meant) this is the reply I got.
NO, the screen is black with sometimes a line or two will show up or a faint outline of the game. You can hear sound when you push the one or two player and turn it on & off. just saying it puts sound out.
I did some looking around and haven't figured out what the issue is yet. My first uneducated guess was maybe bad power supply? I haven't had a chance to inspect the machine first hand yet, hopefully will tomorrow. Any ideas? I already checked out lawnmower mans pacman site and didn't see anything matching this.
The person is asking 300 so I figured it was worth a look for that price.
IG-88
Re: Pacman help
« Reply #1 on: March 09, 2012, 12:01:55 pm »
Definitely worth a look imho. In fact if the cab is in any kind of descent shape I'd be all over it. But there aren't alot that come up in my area. Can you take a psu with you to check it with?
-HarumaN
urgeboy
Re: Pacman help
« Reply #2 on: March 09, 2012, 04:08:26 pm »
unfortunately, I don't have one...I think its definitely worth a look too. I just was trying to figure out if this is a monitor issue or what. I can deal with a new power supply or swapping out boards or something along those lines. I just don't really want to deal with another monitor problem right now. I'm still trying to finish up the monitor issue I had with my APB.
IG-88
Re: Pacman help
« Reply #3 on: March 09, 2012, 05:22:50 pm »
I hear that. Do you have a friend/local collector that has a board or psu you could borrow? Or maybe have them come along for some advice/support? You could also use the issues it's having as a bargaining chip. Maybe wheedle the seller down on price....
-HarumaN
boardjunkie
  • Last login:March 05, 2019, 06:05:58 pm
Re: Pacman help
« Reply #4 on: May 25, 2012, 09:32:15 am »
There is no "psu" since the pwr supply is on the logic board. It takes ac inputs directly from the pwr transfomer.
boardjunkie
Re: Pacman help
« Reply #5 on: May 26, 2012, 10:47:12 am »
Also, I repair Pac series boards if you end up with this and want it repaired.
ed12
Re: Pacman help
« Reply #6 on: May 26, 2012, 02:50:22 pm »
hi
dido to what boardjunkie
has stated...that aside i have by-passed most of the linear stuff on all
pac serie's board's >forget the main board name :namco something: <
that oringal board made by namco was used in most if not all of midway's
game of them year's,if u know how to use a volt meter???,u can chk for +5
it must be between 4.8-5.2vdc,this control's all logic
sound is +12vdc,but the odd faint line tell's me boardjunkie
is about to get a repair job,for the simple fact if u do not understand the z80 logic stuff,u will chase your tail..
hint here get a copy of the :master: midway file for that serie's
and u will see the video gen stage
good luck
ed
