Author Topic: Living with an Arcade monitor and a ArcadeVGA card. Help.  (Read 2755 times)
« on: February 26, 2012, 12:31:00 pm »
Many of you know I have built a lot of cabs, but only recently have I started using a real arcade monitor with a ArcadeVGA card. After speaking with several people and reading some posts, I wanted to run my experiences past you guys and see if those of you using a arcade monitor have the same experiences I have.
My hardware: Well Gardner K7000 25" and a ArcadeVGA PCI-e card
My software: I'm running an older version of mame, but it's not ancient. I belive it's in the 96 or 105 neighborhood. It's the version right before they quit using HI files to record the high score.
My issues are mostly settled around resolution.
  • Some games will not display properly at all, unless I manually adjust the vertical/horizontal resolutions
  • many of the games work, but the screen is squished or more times than not don't fill the screen
  • Some games won't display at all
My question: is this how it is with a real arcade monitor and AVGA card? If so, I may switch to a tri-sync like I use on my vertical cabinet. I've used a TV in the past, and it used to trim some games, but it had much more compatibility than this arcade monitor does. If there are settings I need to change, I'd sure love to hear them.
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
Re: Living with an Arcade monitor and a ArcadeVGA card. Help.
« Reply #1 on: February 27, 2012, 10:11:51 am »
Have you run the AVRES utility which has a link on the ArcadeVGA install page on our site? This should correct these issues.
Andy
« Reply #2 on: February 27, 2012, 03:12:14 pm »
Andy
No I have not. Cool! I'll try it when I get home.
Just looked for it. I couldn't find a program called AVres. I found Quickres, and switchres. I'm currently using Quickres.
« Last Edit: February 27, 2012, 03:16:42 pm by leapinlew »
AndyWarne
    • Ultimarc
