Author Topic: Dreamcast USB Controller?  (Read 9575 times)
gamepimp
  • Last login:December 20, 2025, 10:42:56 pm
« on: February 17, 2012, 07:26:51 pm »
Hi all. I'd like to get an actual Dreamcast controller that I can connect to the computer thru USB so I can play games via NullDC. I can't seem to locate a USB adapter for this type of controller or a circuit that I can solder inside of a controller to convert to USB. Does anyone know if either of these things exist?
crashwg
By the thorax and abdomen
Lemme say it again
In my land of pretend
I use bees as a mf'n pen
gamepimp
Re: Dreamcast USB Controller?
« Reply #2 on: February 18, 2012, 03:17:09 pm »
Perfect. Thanx!
« Reply #3 on: February 19, 2012, 08:21:12 pm »
just and FYI, the trio linker (original) has zero support and doesnt work with Win7 64, however its plug and play with winXP and is pretty awesome.
gamepimp
« Reply #4 on: February 20, 2012, 02:53:00 pm »
The Trio Linker Plus II says its Win 7 compatible. So it should be P & P with Win 7 64-bit right? At least that's what it seems like from what I've read online. Does anyone know for sure?
« Reply #5 on: February 20, 2012, 09:52:11 pm »
the trio II does work with win7 (both 32 and 64) but the original trio linker doesnt work with win 7 64bit
gamepimp
« Reply #6 on: February 20, 2012, 10:56:31 pm »
Ok. Thx 4 confirming!
