Author Topic: Car Speakers to PC?  (Read 16147 times)
Dalgaard
  • Last login:April 05, 2015, 01:42:14 pm
Car Speakers to PC?
« on: February 15, 2012, 02:03:21 pm »
What's the easiest way to get a pair of car speakers connected to the computer? I've never worked with audio equipment before, and have tried googling this. One page recommended simply splicing the wires to a minijack? But on the same page, some guy said that there wouldn't be enough power for the speakers that way?
Do I need an amplifier or perhaps using an active subwoofer is easier?
The simplest setup possible...if anyone could help, that would be great :)
elkameleon
Re: Car Speakers to PC?
« Reply #1 on: February 15, 2012, 02:19:13 pm »
First, get yourself an amp, whatever works for your budget and speaker wattage. You'll need to get one with a power supply brick, unless you want to install a car battery into your project! :lol Next get one of these:
I'm sure there are others out there with more knowledge than I, but this will get you started for sure.
« Reply #2 on: February 15, 2012, 02:20:17 pm »
Yes, you need an amp, and be careful to keep those speakers away from any crt monitors, hard drives, and your computer.  They aren't shielded.
Dalgaard
« Reply #3 on: February 18, 2012, 04:29:39 am »
Thanks a lot for the help :)
matsadona
« Reply #4 on: February 24, 2012, 04:01:10 am »
There are a lot of solutions to choose from, but if you want to go the 12V road here are two examples:
http://www.dealextreme.com/p/y148-audio-amplifier-module-93121
http://www.dealextreme.com/p/60w-stereo-audio-amplifier-for-car-motorcycle-golf-cart-red-91350
In my cabinet I use a standard 2.1 PC speaker setup (built in amplifier/sub), but scrapped the satellites and connect two car speakers instead.
« Reply #5 on: February 24, 2012, 07:43:05 am »
portugese pirate
  • Last login:March 06, 2025, 06:07:58 pm
« Reply #6 on: February 26, 2012, 06:37:50 pm »
believe or not I used the wifes cookie sheets to sheild the monitor and hard drive from the speakers........a word of advice if your going to use wifes cookie sheets, its easier to ask for forgiveness then to ask for permission
toeknee1973
  • Last login:June 09, 2017, 09:24:13 pm
« Reply #7 on: February 27, 2012, 12:04:43 am »
maybe you should look into powered speakers.... they are better and easier than having to modify your project to use car audio equipment.. just my opinion.
dholcombe
  • Last login:October 24, 2012, 10:45:39 pm
« Reply #8 on: February 27, 2012, 01:23:28 am »
I'm using car speakers and a lepai amp I got off parts express that is typcially between $20-$25. The amp takes mini jack as one type of input
