Author Topic: WG 25K7194 Monitor connection question  (Read 1735 times)
magugin
  • Newbie
  • Last login:May 14, 2012, 01:05:22 am
« on: February 13, 2012, 11:58:25 pm »
I have a Wells Gardner Model 25K7194 and I have a connection question that is probably pretty simple.  This is my first post so please go easy on me... :)
On the WG K7194 Monitor board section where you connect the video cables there is a set of 6 pin connections (left side) and a set of 3 pins (right side).  I know that from left to right they are Red, Green, Blue, Gnd, +V.Sync, +H.Sync  and then the set of 3 are Gnd, -V.Sync, -H.Sync.
I purchased what was supposed to be a WG monitor cable but arrived with just the 6 pins, with the +V.Sync Yellow and the +H. Sync White.
My questions:
1.  I bought a Super Jamma Plus harness which already had the wires grouped and labeled.  The "Video" group has Red, Green, Blue, Black and a white wire (5wires)- What does the white wire plug into?  If I matched the colors to the 6 pin monitor cable I bought it would go to the +H. Sync.
2.  What are the +/- V. and H. Sychs used for?   The harness that I pulled out did not use all of the pins.  It had the Red, Green, Blue and Black of course, but then had a white wire going over to the far right pin, which I think is the -H.Sync.  (I pulled out a custom harness that used a PlayStation as the game console and translated the controls to buttons on the CP- anyone want it? LOL!)  I think knowing what the +/-V. and H. Syncs are for will help.
3.  Did I buy the wrong monitor cable (just having a 6 pin connection)?
4.  If I do use the monitor cable that I have, I will have one extra/unused wire if I match the wires up with the "Video" cluster in the Jamma Plus Harness.
Thank you for any help or knowledge you can share!
Magugin
buffett
  • Last login:December 13, 2016, 01:28:10 am
Re: WG 25K7194 Monitor connection question
« Reply #1 on: March 11, 2012, 05:48:21 am »
it should go like this. starting from the back of the chassis header going toward the tube.
1 red
2 green
3 blue
4 ground - black
5 not used for what you need.
6 not used for what you need.
7 key/blank space between header pins
8 ground - black if not using pin 4.
9 not used for what you need.
10 your wite / synk wire goes here.
Peace
Buffett
Come to MAGfest and game in the 24-7 arcade for 4 days. www.magfest.org  And see my collection of 90+ Arcades and growing.
Need your (K7000, 4900, std/med res 13"-25") or Sanyo fixed!!!! pm me.
Visit my website. www.thearcadebuffett.com For Monitor and PCB repairs.
Fully rebuilt chassis ready to ship. Trade'ins welcome
I have met --- Tim McVey --- world nibbler champion and many of you have not.
