Author Topic: MAMEWAH v0.96 Released!  (Read 7837 times)
kujina
  • Last login:November 04, 2021, 12:07:40 pm
Re:MAMEWAH v0.96 Released!
« Reply #40 on: October 06, 2003, 09:23:35 am »
Hi
In this entry in the registry
HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\Winlogon
I added a string value called "Shell" and d:\mamewah\mamewah.exe
When I log in all I get is the windows background, I check processes in task manager and there are no instances of mamewah running. Then looking at the mamewah config most of it has gone. I can then replace the .exe with the previous version of mamwah, delete the cfg files, logout, log back in - it works.
Upgrading back to 0.96 - same problem again.
papaschtroumpf
  • Last login:July 23, 2013, 11:41:10 pm
  • Have a Cow!
« Reply #41 on: October 06, 2003, 01:02:30 pm »
Where can I read more about using mamewah (or other front ends for that matter) as a shell? What are the advantages of doing this? I tried running mamewah as a shell by changing the shell= in my windows system.ini (I'm running Win98SE) and I'm not sure what the benefit is: you still see the windows backgroud while the shell satrts, then you can't exit to windows or boot to windows to do maintenance, like adding new roms
vitaflo
  • Last login:January 14, 2020, 08:11:04 pm
    • ASMBLR
« Reply #42 on: October 06, 2003, 01:50:27 pm »
You can get rid of the windows background if you want, there are various ways to do this.  And you can do maintenace as well.  Just do ctrl-alt-del to log off and log in as a different (admin) user that doesn't have Mamewah as its shell.
papaschtroumpf
  • Have a Cow!
« Reply #43 on: October 06, 2003, 04:05:07 pm »
OK, but what are the advantages? does it run faster/better or is it purely cosmetic?
I was wondering if running it as a shell would prevent other stuff from loading (stuff that wouldn't be used for gaming but for maintenance maybe?)
