Author Topic: Rowe CD100B Question  (Read 2250 times)
danno1132
  • Last login:April 06, 2012, 09:00:17 pm
« on: February 06, 2012, 07:48:38 pm »
Hi.....I have a Rowe CD100B it has a motor like the one that spins the CD's at the top located right under the top flourescent light (righthand side).....Does anyone know what is supposed to be there?....Also my number 2 and 6 are not working.....is it easier to just send the board off for repair....Is this a common problem on these as I have heard of someone with the same problem....thanks
lilshawn
  • Last login:March 16, 2026, 03:44:11 pm
Re: Rowe CD100B Question
« Reply #1 on: February 06, 2012, 09:57:35 pm »
there is supposed to be a colored tube over the fluorescent tube, the motor makes it spin and change the colors visible in the window.
check ebay for a replacement keypad or buttons. the buttons are awful and crap out all the time. if you feel adventurous you can just replace the button, otherwise, just buy a whole working keypad.
Ken Layton
  • Guru
  • Technician
« Reply #2 on: February 07, 2012, 12:34:28 pm »
You can get the boards repaired and buy Rowe parts from Bruce Wentworth.
http://www.rowejukeboxrepair.com/
Mention I refered you.
