Author Topic: Possible to connect this SSD to a SATA connector?  (Read 3050 times)
jimmy2x2x
« on: January 31, 2012, 03:38:53 pm »
I have this recovered drive from a dell mini 9 and would like to use it on a desktop pc
Anyone know what cable I would need?
Cheers
Re: Possible to connect this SSD to a SATA connector?
« Reply #1 on: January 31, 2012, 03:44:15 pm »
A motherboard with a PCIe slot.
jimmy2x2x
« Reply #2 on: January 31, 2012, 04:15:26 pm »
err how might that help?
« Reply #3 on: January 31, 2012, 04:18:00 pm »
AFAIK, that drive plugs into a PCIe slot.
SNAAKE
  • Trade Count: (+29)
« Reply #4 on: January 31, 2012, 04:30:27 pm »
you should ban him for questioning you!
« Reply #5 on: January 31, 2012, 04:37:30 pm »
Rofl
MonMotha
« Reply #6 on: February 01, 2012, 12:35:46 am »
What you have there is very likely what is being called "mSATA".  Basically, it's SATA on a mini-PCIe slot.  I very much dislike this because they're not really compatible in any way whatsoever.  They just re-used the connector because it was convenient.  It would be like putting Ethernet on a USB connector "because we had a lot of them laying around" (hey, kinda like the JVS IO "standard").
If indeed this is mSATA, you could theoretically just get a special cable to hook it straight up to a normal SATA port, but I'm not sure anyone makes one.  They're intended to get dumped into specially designed laptops.  You could try hacking up a SATA cable and soldering it down to the right places on the connector, but uh, yeah.  Good luck: it's small, and it has to work at 3GHz.
If this is NOT mSATA and is in fact a real mini-PCIe card that just happens to have an SSD implemented on it (these were made, but I've never been able to find one - I'd kinda like one for my laptop, actually), then there's no way to hook it up to a standard SATA connector (because it's not SATA), but you could either put it in a standard mini-PCIe socket or buy a mini-PCIe to PCIe 1x carrier card.
Whatever you have, it's a Dell part.  Dell can probably tell you what it is specifically, but they probably won't give much help beyond "put it back in your Mini-9".
lilshawn
  • Last login:Yesterday at 10:09:11 pm
« Reply #7 on: February 01, 2012, 12:56:49 am »
sigh... do I REALY have to do ALL the googling??
http://www.minipciessd.net/
MonMotha
« Reply #8 on: February 04, 2012, 04:06:18 pm »
None of those appear to be standard mini-PCIe size (either full or half).  They're all about "one and a half" size.  That's what was commonly used in the netbooks, but it won't fit in a standard mini-PCIe slot.  My recollection is that many of those are also not actually PCIe but rather mSATA or similar with a proprietary pinout.  At least nobody's ever been able to verify to me that they're actually standard mini-PCIe electrically.
ark_ader
  • I glow in the dark.
« Reply #9 on: February 04, 2012, 06:16:30 pm »
Wow that looks cool.  How big is the capacity? 20gb?
lilshawn
« Reply #10 on: February 05, 2012, 09:52:23 am »
and then companies start wondering why the get damaged product back cause users plugged ---steaming pile of meadow muffin--- into the wrong connector. THERE IS A REASON STUFF HAS DIFFERENT CONNECTORS ON THEM!!!
jimmy2x2x
« Reply #11 on: February 05, 2012, 09:55:22 am »
Thanks for all the (various) information, I think I will leave it where it is ;)
lilshawn
« Reply #12 on: February 05, 2012, 10:01:34 am »
/btw they do have a mini sata to standard sata adapters available.
rockyrocket
« Reply #13 on: February 05, 2012, 11:22:34 am »
So I just tried the same thing with the exact same drive, bought one of these adaptors..
http://www.amazon.co.uk/RunCore-70mm-50mm-Converter-Adapter/dp/B003BK4OZ8
And everything fits fine but it turns out the drive uses pata (it is infact described as a pata ssd) so no it did not work.
Shame as I had plans for it!.
