Author Topic: Strange Mamewah Problem  (Read 1163 times)
BlackThorne
  • Last login:June 20, 2004, 05:31:57 am
« on: September 22, 2003, 04:58:20 pm »
I just reinstalled WinXP on my computer and now i encounter a strange problem with mamewah. The fonts of the gamelist and in the menus are about 10 times as big as they should be. I tried to change it in the layout designer but it didn't help. Btw. i use v0.955b. I also tried v0.954b which had the same problem. Before i reinstalled Windows mamewah worked totally fine.
Re:Strange Mamewah Problem
« Reply #1 on: September 22, 2003, 05:49:43 pm »
What language / regional settings did you use?
MAMEWAH currently has a problem with non-English languages which do not use '.' as a decimal symbol.  I expect this is the problem here - change your language setting to English and set the decimal symbol to '.' in Control Panel if possible.  This *may* be fixed in the next release...
BlackThorne
« Reply #2 on: September 23, 2003, 08:30:11 am »
 :) Thanks a lot Minwah! That did it. Everything looks normal again. Btw. i want to say that i really like Mamewah and i'm looking forward to the next release. Keep up the nice work!
