Author Topic: Emulators that don't support joystick?  (Read 1521 times)
fantoboy
  • Last login:May 24, 2017, 02:02:13 pm
  • I'm a mushroom cloud layin' motha fu($@!
« on: January 19, 2012, 12:57:53 pm »
I recently switched from using a logitech rumblepad 2 with xpadder to a 360 MADCATZ TE arcade stick.  I have a hyperspin setup with lots of emulators and pc games.  I am having an issue where SSFIV is recognizing the joystick and xpadder together, so all inputs are doubled.  I'm thinking of eliminating xpadder and just using it as a joystick.  It's been years since I set most of my games up.  Are there emulators or games that you can think of where I will have an issue setting them up because they only support keyboard?  Or am I better off trying to figure out a solution for SSFIV instead?  Suggestions?
Zrooney
  • Last login:December 27, 2018, 07:33:27 am
  • Master Procrastinator
Re: Emulators that don't support joystick?
« Reply #1 on: January 31, 2012, 09:35:43 pm »
Just out of curiosity, what is SSFIV?  Don't quote me on this but you should just get rid of Xpadder because it is doubling up your inputs ( you only want one set of inputs).  Most games with MAME, at least have the controls configured for a joystick with buttons, but that is only MAME.  And if you want something  a little more newer ( N64 or Dreamcast), you just need to configure you controls for the controller the emulator is using, but not each specific game.  Hope this helps.
fantoboy
« Reply #2 on: January 31, 2012, 10:25:28 pm »
SSFIV = Super Street Fighter 4
