Author Topic: Atari 4" Trackball Wood CP Flush Mount  (Read 2140 times)
yo1dog
  • Last login:November 12, 2024, 04:38:47 pm
    • MikeArcade
« on: January 12, 2012, 05:45:47 pm »
So I am considering getting an Atari 4" trackball because I love their huge size (that's what she said). Problem is I have a 3/4" wood control panel and I am trying to keep everything flush mounted. In this case I would not mind some bolt heads showing.
I was thinking of removing the plexiglass and metal top, drilling the circular hole for the ball, and routing the wood to 1/8" thick for the trackball base. Then I could either drive bolts through the top or put something underneath it to hold it up.
I am worried that the 1/8" wood would be too thin to support someone smashing on the trackball. Therefore, bolting from the top will not be a viable option.
I think the best solution is to create something to hold it from underneath. It would secure the trackball against the control panel and in place. This would allow for a completely flush mount as well. See the following crapagram:
Red: Tranckball
Blue: Harness/support
Black: Control Panel
Grey: Bolts that holds harness/support to control panel
What do you guys think?
Edit:
The wood is 3/4" Birch "Plywood Hardwood" and I do NOT have any plexiglass overlay.
« Last Edit: January 12, 2012, 05:47:46 pm by yo1dog »
newmanfamilyvlogs
    • Newman Family Vlogs
Re: Atari 4" Trackball Wood CP Flush Mount
« Reply #1 on: January 12, 2012, 05:54:42 pm »
yo1dog
    • MikeArcade
« Reply #2 on: January 12, 2012, 06:31:41 pm »
My control panel is bare wood (no paint, graphic overlay, plexiglass, etc) with just a finish, and I am trying to keep it that way. A big black mounting plate would be so ugly!
Crazy Cooter
  • Last login:August 19, 2025, 11:29:13 pm
« Reply #3 on: January 12, 2012, 08:02:54 pm »
Build a "basket"to hold it from the bottom (in addition to routing the top thin).
yo1dog
    • MikeArcade
« Reply #4 on: January 12, 2012, 08:04:32 pm »
That's exactly what I was saying
Crazy Cooter
« Reply #5 on: January 12, 2012, 08:17:50 pm »
Build it with a "lip" so you can rambo a dozen screws upward into the control panel and you won't need to have bolts showing.  Just make sure the basket it tight around the sides/edges and it won't go anywhere.
_        _
 |____|
Like that.
bkenobi
« Reply #6 on: January 13, 2012, 03:17:12 pm »
Just a thought, but if you are using 3/4" wood, then you will only have 1/2" threads holding the TB in place.  You could add a bunch of screws, but that would mean more locations to remove for maintenance.  I was thinking about a slightly different approach that might work well.  What if you were to add a strip of wood around the perimeter (or at least 2 sides) of the track ball mounting location.  These strips would be glued down, but prior to applying glue, insert 4 T-nuts facing down.  That would allow you to have a nice metal threading to screw into that won't wear out.  Then you can make a cradle out of whatever you want (bent sheet metal, wood, etc) and you would be able to screw down the TB frame nice and snug without any issue of stripping the wood screws or bolts visible from above.
yo1dog
    • MikeArcade
« Reply #7 on: January 13, 2012, 03:23:26 pm »
Great idea. Thanks!
