Author Topic: GroovyMame + Soft-15khz does it work?  (Read 3938 times)
jvlk
  • Last login:September 28, 2013, 08:44:24 am
« on: January 12, 2012, 04:13:25 pm »
Since I run a hyperspin setup I can't really use the crt_emudrivers for groovymame.
So my question was, can I use the newest ati drivers + soft-15Khz with groovymame?
I know I don't get all those resolutions but is groovymame still be able to calculate the closest resolution of what I have with soft-15Khz?
Calamity
  • Moderator
  • Last login:July 19, 2026, 05:56:58 am
  • Quote me with care
Re: GroovyMame + Soft-15khz does it work?
« Reply #1 on: January 12, 2012, 04:45:13 pm »
Yes it should work but not without issues. Current GM build doesn't work fine when resolutions like 321x are defined, as Soft-15Khz does, this is a known problem that I need to fix soon.
Steps to create a log:
