Author Topic: Replacing Capacitors  (Read 1635 times)
Peja
  • Last login:June 09, 2015, 04:48:22 pm
« on: January 10, 2012, 01:52:36 pm »
I am currently replacing my caps with a cap kit I got from the Bob Roberts(very easy to deal with, can't say enough about him...even got a free calendar!)
According to his spec sheet, I am supposed to replace this C110 cap with a 4.7uf 50v cap, but the previous cap that is in there does not look the same and is a lot wider.  Before I proceed, I just want to know if I should go ahead and still replace this cap.  Here is a pic.  The brown one is the one that came off of the board and the blue is the one I am supposed to replace it with.
Thanks for looking!!
grantspain
Re: Replacing Capacitors
« Reply #1 on: January 10, 2012, 04:44:44 pm »
don't look right to me,what does Mr Roberts say?
Peja
« Reply #2 on: January 10, 2012, 04:47:48 pm »
Yes, I just received an email from him.  He said kits include caps for the board that various mfrs modify.  I should have left that one alone since my board doesn't use it......now I just need to know if there is a positive and a negative on that old cap and if it matters which way I put it in.....
Thanks.
MonMotha
« Reply #3 on: January 10, 2012, 05:31:57 pm »
That type of brown cap you've pictured is generally not polarized, so you can put it in either way.
Peja
« Reply #4 on: January 10, 2012, 05:37:58 pm »
Thank you MonMotha......that is the answer I was looking for!!
