Author Topic: Larger IR sensor bar for AIMTrak?  (Read 4764 times)
johnk
  • Last login:January 17, 2019, 04:29:50 pm
« on: January 08, 2012, 03:12:06 am »
Would I be able to use the gun closer to the screen if I get a larger IR sensor bar?  Such as:
http://www.arcadeguns.com/index.php?main_page=product_info&cPath=2&products_id=225
lettuce
  • Make It So!
Re: Larger IR sensor bar for AIMTrak?
« Reply #1 on: January 08, 2012, 06:50:31 am »
I think this might be something Andy might have to look into as the current sensor bar he uses would be fine for your traditional Arcade 4:3 display, but when your start using it with a 40" + LCD display it can becomes a bit of a problem. If this is something Andy is considering i would happly try a prototype out and give feedback, after all it can only help sales if he offers 2 different sensor bars?
Afterburner
  • Last login:July 27, 2016, 01:02:00 am
« Reply #2 on: January 08, 2012, 10:36:44 am »
I don't know about closer to the screen.  But all of the guns appear to be Aimtrak internals, so the super LED bar should work with an existing Aimtrak setup.
However, I think I recall that what really lets you get closer to the screen is really the field-of-view of the sensor in the gun itself and the angle that the LEDs are mounted at relative to the gun.
It sounds to me like the "Super" LED bar is really just a higher power LED bar that lets you get further away for a large screen, rather than closer up for a smaller one.
  2-player upright dual trackball / dual 8-way rotary joysticks - built from scratch
johnk
« Reply #3 on: January 08, 2012, 11:15:01 am »
Andy gave me an answer to this via email, as I had also asked him about it directly:
"The larger bar would be OK for a larger screen, not smaller. The gun cannot be used closer as the field of view of the sensor is 60 degrees and that is what defines the distance. If closer it would lose sight when aimed at the edges."
(Thanks for the quick replies Andy.)
lettuce
  • Make It So!
« Reply #4 on: January 08, 2012, 01:39:56 pm »
Thanks for the update. I think Andy should defo start to stock a larger Sensor bar then, and give info about the use of it for say a 32" Widescreen screen and above, i could of done with a larger bar for my 42" :(
SammyWI
« Reply #5 on: January 08, 2012, 02:47:23 pm »
Interesting.  I'm planning on a front projection shooting setup for my next project.  This might be useful.
