Author Topic: return windows shell  (Read 2144 times)
Fry
  • Last login:February 12, 2012, 11:58:08 am
« on: January 07, 2012, 09:38:12 am »
Hi guys,
I'm experimenting with hiding windows, not showing with startup etc. This works pretty well now. I use Instantsheller to start up HyperSpin as shell. Upon exiting HS I want to automatically return to my windows shell incl. desktop. How do I fix this? I can run a .exe on exit, but if I run explorer.exe I just get back one screen. I need to somehow to really set it as shell. Any thoughts?
Fry.
Gray_Area
  • -Banned-
  • -Banned-
Re: return windows shell
« Reply #1 on: January 09, 2012, 11:43:00 pm »
Since you're not using it exclusively as an arcade machine, I suggest not shelling it, and simply starting it when you want. Make sure it's set to fullscreen.
I do this all the time with Mala. That way, I don't even have to exit Mala if I want to do something computer-related. I press the Windows button, and can select stuff from the Start Menu or the Task Bar. And my 'arcade ambience' continues in the background.
-Banned-
Fry
« Reply #2 on: January 12, 2012, 06:08:42 am »
Hi Gray_Area, thank you for your reply. Actually I do want to use it exclusively as an acade machine. I want to hide my pc as much as possible, it must look and feel like an arcade. So I definately don't want to show Windows. My ideal situation is that when I plug in the power, everything starts up automatically and the user ends up in his game selection screen without ever seeing anything PC related.
Fry
Dawgz Rule
  • Last login:August 22, 2024, 07:18:55 pm
  • The more people I meet, the more I like my dogs
« Reply #3 on: January 12, 2012, 06:17:25 am »
There are a number of things you can do to hide Windows.  Google the following:
 - How to disable Windows splash screen
 - How to remove the recycle bin from windows desktop
 - How to remove windows welcome screen
 - How to auto login windows (I think it is "control userpasswords2)
Along with that, I set my taskbar to autohide, my front end to load at startup, and desktop background to black.
When I turn on my cabinet, you never see anything Windows related. Haven't figured out an easy solution to eliminate the Windows Shutdown screen.
« Last Edit: January 12, 2012, 06:30:03 am by Dawgz Rule »
