Author Topic: need help with wireing my led push buttons to a pac drive  (Read 2165 times)
mebronx2000
  • Last login:August 03, 2024, 06:20:32 pm
« on: January 05, 2012, 09:28:38 pm »
bought a pac drive i have 12v leds all daisy chainded together for the power and the ground then they are hooked up to a molex then to my pc ! what part goes to the pac drive please help i show some pics of my set up thanks  :applaud: :notworthy:
Re: need help with wireing my led push buttons to a pac drive
« Reply #1 on: January 05, 2012, 09:52:42 pm »
http://ultimarc.com/pacdrive.html
Shows how to wire LEDs up to the PAC-Drive. If you want them individually controlled, your grounds are hooked up wrong. If you don't want them individually controlled, you don't need a PAC-Drive.
mebronx2000
« Reply #2 on: January 05, 2012, 10:42:09 pm »
i don understand those instructions thats why i posted here also i want them individually controlled thanks anyway  :banghead:
« Reply #3 on: January 05, 2012, 11:04:03 pm »
If using 5V (I know, you have 12V LEDs, but they can be ran off 5V), run your wires like this:
If using 12V (from the computer's power supply), run your wires like this:
Notice each ground from each LED goes to its own terminal on the PAC-Drive. You need to at least rewire your grounds. I don't know how much simpler I can make this, do you want me to draw a picture? Oh, wait... :banghead:
« Last Edit: January 05, 2012, 11:06:51 pm by Nephasth »
mebronx2000
« Reply #4 on: January 05, 2012, 11:58:21 pm »
 :applaud: now that i understand !!! i just needed to know what wire go's to the pac drive it does not say that on the site !!! thank you so much  :notworthy: :cheers: sorry i am slow ! not to bright  :cry: hard for me to understand the simplest things  :dunno thanks again
« Reply #5 on: January 06, 2012, 12:08:27 am »
Also, it's hard to tell what is going on in your third pic, but it looks like you are tapping into the connector with the blue and white wires. If that's the case, it looks like you've tapped into 5V from the computer's power supply. The yellow wire is 12V. If you're satisfied with the brightness of the LEDs at 5V, you don't need to tap into the computer's power supply at all, you can just run your positive wire straight from the PAC-Drive like in the first pic to your LEDs and they will get their power via USB. If I have mistaken what was going on in your third pic, ignore all this.
« Last Edit: January 06, 2012, 12:10:59 am by Nephasth »
mebronx2000
« Reply #6 on: January 06, 2012, 01:08:14 am »
thanks i will do that  :cheers: :applaud: :notworthy:
