Author Topic: WG 25K7000 with static - Is it normal?  (Read 1689 times)
ebo0763
  • Last login:May 23, 2016, 12:37:58 am
« on: January 05, 2012, 05:16:56 pm »
I notice there's a little static at the front of the monitor, k7000 25" that is. I reinstalled the chassis and then I noticed the static, I'm not sure if it was there before...
Is static normal? And would an improper ground would cause this? What else?
grantspain
Re: WG 25K7000 with static - Is it normal?
« Reply #1 on: January 05, 2012, 05:42:22 pm »
static is quite normal
just check the dag earth is connected to the neck card
ebo0763
« Reply #2 on: January 05, 2012, 09:26:09 pm »
Thanks! That was the problem.
