Author Topic: Powering a 5v DC illuminated button  (Read 2660 times)
Corbo
  • Last login:June 24, 2019, 07:49:12 am
  • I've not seen such bravery
    • Minicade - Mini Gauntlet MAME project
« on: January 03, 2012, 04:21:35 pm »
Hi,
Can anyone suggest a simple way to illuminate 2 LED push buttons from a PC motherboard, without using an external board like an LED WIZ?
E.g. is there a simple hack using a molex cable?
Thanks for any suggestions in advance.
_____________________
Wizard needs food, badly!
My mini arcade project:  http://minicade.blogspot.com/
Re: Powering a 5v DC illuminated button
« Reply #1 on: January 03, 2012, 04:58:03 pm »
If you want them on all the time when the computer is on, just tap into a 5V (red) wire from an unused connector on you computer's power supply. Don't forget your ground (black wire from the PSU).
Corbo
« Reply #2 on: January 04, 2012, 08:06:05 am »
Yes on all the time is all I need.
I'll have a play with the red and black cables from a molex connector, sounds simple enough!  Thanks for your help.
« Reply #3 on: January 04, 2012, 10:18:43 am »
just remember red is 5v yellow is 12v, if you hook it up to the 12v it'll be REALLY BRIGHT for about a second. Either black however will work.
Corbo
« Reply #4 on: January 04, 2012, 03:00:21 pm »
Interesting, my 8" LCD is 12V.  Think I can use the same trick to eliminate using the DC plug I use at the moment?
« Reply #5 on: January 04, 2012, 03:09:35 pm »
see the right side of the marquee
Corbo
« Reply #6 on: January 04, 2012, 04:34:18 pm »
Nice, You're running that off a hacked hard drive power cable?
Corbo
« Reply #7 on: January 05, 2012, 04:45:41 am »
That worked a treat thanks, and in the process it has solved a problem I had with a wavering picture so there was a problem with my original DC adapter.
Just 1 plug for it all is far neater.  Thanks for your time.
« Reply #8 on: January 09, 2012, 11:28:08 am »
yup the LCD and the LEDs on the panel
