Author Topic: Control panel help  (Read 1796 times)
Mark Thomas
  • Last login:August 16, 2014, 07:41:56 am
Control panel help
« on: January 02, 2012, 05:25:17 pm »
Hi guys,
I have seen this pic of a control panel that has an easy open style. I would like to do this with my panel but not sure what I need to buy or how it is done/works. Could you please shed some light on this?
mgb
  • Last login:March 25, 2026, 09:52:08 pm
  • North East, US
Re: Control panel help
« Reply #1 on: January 02, 2012, 05:27:53 pm »
My first control panel opened like that.
I used cabinet hinges from home depot. I had to use a 3/4" spacer to space the hinge off of the control panel and it worked great.
The hinges I used were like these http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10051&productId=202212846&langId=-1&catalogId=10053&MERCH=REC-_-search-2-_-NA-_-202212846-_-N&locStoreNum=6217 but not that expensive
« Last Edit: January 02, 2012, 05:30:04 pm by mgb »
Mark Thomas
« Reply #2 on: January 02, 2012, 06:15:47 pm »
Thanks for the reply buddy, they look very similar to hinges that are in my kitchen cabinets. Do you have any pics of the hinges in place and how does the panel stay in place I am a bit worried that with some frantic play the panel may lift up.
mgb
  • North East, US
« Reply #3 on: January 02, 2012, 11:03:10 pm »
Yeah they're the same hinges you would use for some kitchen cabinet doors.
heres a pic of them on my old control panel
You can also use a piano hinge to accomplish this.
For holding the panel shut, I used hold down clamps, kinda like these http://www.twistedquarter.com/index.php?main_page=product_info&cPath=219_225&products_id=40&zenid=3csohgmfaururkf95s7ike0u84
but you have to be able to access them from underneath to open them. I had a section cut out on the bottom of my control panel so that I can reach up through the coin door and unclamp them.
I guess alternately, you can use magnets or even velcro to hold it down.
I have left my unclamped mant times and it was ok.
Mark Thomas
« Reply #4 on: January 03, 2012, 01:17:35 pm »
Thank you for this mate its really helped me out. I think I will get some magnet connector to keep it in place.
