Author Topic: What do you think of this brand new chassis?  (Read 1747 times)
ebo0763
  • Last login:May 23, 2016, 12:37:58 am
« on: December 23, 2011, 06:31:44 pm »
I've found this and I'm wondering if it's any good... And do you know what CGA/EGA stands for?
http://www.arcademonitor.com/Arcade-Monitor-Parts/25-inch-chassis-yoke.php
« Last Edit: December 23, 2011, 06:35:36 pm by ebo0763 »
grantspain
Re: What do you think of this brand new chassis?
« Reply #1 on: December 23, 2011, 07:37:09 pm »
colour graphics adapter 15khz(standard older/jamma video signal) low res
enhanced graphics adapter 24khz(sega plus other early/mid 90's) medium res
that chassis you linked to can do both but I can't see if it's auto or manual switching-looks pretty good though
lilshawn
  • Last login:September 11, 2025, 02:53:13 pm
« Reply #2 on: December 23, 2011, 07:50:34 pm »
looks like a pentranic chassis.
 it's a manual switch (have to move a cable to a different header block.)
ebo0763
« Reply #3 on: December 23, 2011, 08:00:42 pm »
Right, I don't mind though. I would only use 15khz anyways.
Is there often an incompatibility between yoke and tube? (other than the pins layout of course)
grantspain
« Reply #4 on: December 23, 2011, 08:28:55 pm »
hit and hope mate,sometimes you are lucky and get good geometry-other times you get what you have,although horizontal compression is most common
