Author Topic: Any source for lasercut or pre-fabbed wood control panels?  (Read 1484 times)
Dragonman73
  • Last login:April 08, 2018, 07:48:01 pm
« on: December 19, 2011, 08:44:18 am »
Just curious, I was wondering if there was a source for "assemble" yourself wood control panels that are pre-cut and covered in black formica?
I don't need the wiring done...just a CP with all the holes cut out and all i have to do is put it together? I have seen the ready to assemble cabinets but haven't see the CP by itself.
And i'm not interested in X-arcade  :)
BobA
  • What Me Worry?
Re: Any source for lasercut or pre-fabbed wood control panels?
« Reply #1 on: December 19, 2011, 09:00:36 am »
Check here.  CP Kits
bkenobi
« Reply #2 on: December 19, 2011, 02:42:21 pm »
I don't think you'd be able to get a laser to cut MDF thick enough for a CP without setting things on fire or at least scorching things really good!  I think the accepted method for cutting CP's with an automated tool would be on a CNC mill.
Dragonman73
« Reply #3 on: December 19, 2011, 02:51:26 pm »
I used to work at a greeting card factory (for 11 years) and used to laser cut 1/2" - 3/4" plywood for the tooling dies..so I've seen it done and we never had a fire  :) I guess that's why I threw lasercut out there as an option because it was on my mind...but your correct about cnc
laser / cnc..it doesn't matter how it's cut to me...I was just checking the options out there of CP's that already had the cutouts.
Peja
  • Last login:June 09, 2015, 04:48:22 pm
« Reply #4 on: December 19, 2011, 04:09:29 pm »
EDIT:
bkenobi beat me to it.
Good Luck....Peja
