Author Topic: No sync with Asus/ATI Post screen.  (Read 2280 times)
Andypc
  • Last login:November 18, 2024, 01:45:58 pm
« on: December 18, 2011, 05:02:59 am »
I have an ATI HD 4670 running in my arcade machine with a Wei-ya Tri Sync arcade monitor. My only problem is that the initial post screen does not sync. The XP boot screen is fine and I have no problem with the resolution once windows has loaded, but I am concerned that the ATI post screen my be at a resolution to high for the monitor. I know it is only brief, but is there a way to force it to 640 x 480 60Hz. I would have thought that it shouls have been this resolution anyway?
« Last Edit: December 24, 2011, 06:08:38 am by Andypc »
lilshawn
  • Last login:Today at 05:21:59 pm
Re: No sync with ATI Post screen.
« Reply #1 on: December 20, 2011, 07:44:17 pm »
it's syncing, it's just not able to support that resoulution.
perhaps your BIOS has a show boot options or disable full screen logo.
many of our big buck hunters run tri sync monitors and show garbled boot screens with no ill effects.
Andypc
« Reply #2 on: December 24, 2011, 06:08:03 am »
The fact it's not syncing means its putting out a resolution higher than 640 x 480 @ 60hz. The post screen does not display a full screen logo. The motherboard is a Asus P5Q-VM. Does anyone know what resolution the post screen is output at or how to change it to VGA?
Andypc
« Reply #3 on: December 27, 2011, 09:07:44 pm »
Problem solved. It was the Marvell IDE controller post screen that was causing the problem and displaying a resolution that was to high. Fortunately I was not using it and have now disabled it in the bios.
MonMotha
Re: No sync with Asus/ATI Post screen.
« Reply #4 on: December 27, 2011, 09:16:12 pm »
A lot of BIOS startup screens (and yes, it will vary with screen if you have any add-on BIOS helpers like from "RAID" controllers) run at ~640x400 @ 70Hz.  This still works out to ~31kHz, but the refresh rate is higher than the standard/more common 60Hz, and a lot of arcade monitors will be unhappy with that.  PC monitors are all designed to handle it, though.
