Author Topic: Stretch Using Hardware Grayed out in Mame32?  (Read 1808 times)
sgreen3827
  • Last login:November 09, 2012, 01:25:05 pm
« on: December 17, 2011, 11:10:47 am »
I'm having issues with a tower I am running Mame32 on, the Stretch Using hardware option is grayed out and as a result some of the games are not displaying full size.  I have run mame32 on several other computers with no issues but for some reason I am missing something on this unit, is there a driver or program I may be missing that allows the hardware stretching?  The hard drive is small at 120g and has less than 10 percent free space could this be causing my issues?  I had previously been using a system running windows 7 and everything was great but I had to switch to the xp tower as windows 7 wouldnt play nice resolution wise with a new Makvision multisync I picked up .  Any suggestions are appreciated!
Steve
Gray_Area
  • -Banned-
  • -Banned-
Re: Stretch Using Hardware Grayed out in Mame32?
« Reply #1 on: December 18, 2011, 10:48:13 pm »
I'll give you two hints:
- it's hardware related
- read the MAME32 help file
-Banned-
sgreen3827
« Reply #2 on: December 19, 2011, 12:35:48 pm »
Problem worked itself out.  Hard drive was 9 years old and maxed on space so I decided to put in a new larger drive with a clean install of XP...after installing the new drive, re-installing XP and all the drivers, mame32 and maximus everything is working 100% as it should!
Gray_Area
  • -Banned-
  • -Banned-
« Reply #3 on: December 22, 2011, 04:56:53 pm »
Usually hwstretch unavailable means the hardware doesn't have enough video memory, or/and the drivers don't support the feature. Probably the new OS installation found the right video drivers, or you manually installed them in the process.
-Banned-
