Author Topic: 19" Vision Pro (CGA/VGA) LCD Monitor  (Read 2255 times)
bent98
  • Last login:February 02, 2019, 03:35:00 pm
  • Hyperspin Moderator
« on: December 06, 2011, 07:02:02 pm »
http://www.dirtcheaptrading.com/index.php?page=shop.product_details&flypage=flypage.tpl&product_id=31&category_id=12&vmcchk=1&option=com_virtuemart&Itemid=16
Has anyone pruchased this monitor?
I want to build a cocktail cabinet and I am wondering if this will work with groovy mame or soft 15khz and display similar modelines as a CRT would.
Heres Specs:
Input Video Signal
Signal : RED, GREEN, BLUE Analog only
 Polarity : Positive
 Level : Analog from 0.714 to 2.5 [VP-P]
 Maximum Dot Clock : 135[MHz]
 Input Sync Signal
Polarity : (+) or (-) H,V Separate or Composite sync
 Level : TTL Compatible
 High : 2.4 ~ 5.0[V]
 Low : 0.0 ~ 0.8[V]
 Scan Frequency : 15 ~ 80.0[KHz]
 Panel Specifications
Display Area 376.32 (H) x 301.06 (V) mm (19” dia.)
 Driver Element a-Si TFT active matrix Dot
 Display Colors 16.78M True Color
 Number of Pixels 1,280 x 1,024 Pixel"
 Pixel Arrangement RGB Vertical Stripe
 Pixel Pitch 0.294 (per one triad) x 0.294) mm (19”)
Display Mode Normally White
 Viewing Angle 80/80/80/80 (U/D/L/R) Degrees CR≥10 (19”)
Contrast Ratio Typ = 700:1 Center of panel (19”)
Response Time Rise = 4.5ms , Fall = 1.5ms Typ. (19”)
White Luminance Typ = 300cd/m2 Cd/m2
Center of panel
 Brightness Uniformity Typ = 80 % %
Dimensions 396 (H) x 324 (V) x 17.5 (D) (Typ) mm (19”)
« Last Edit: December 07, 2011, 07:32:38 am by bent98 »
