Author Topic: Help!!! pc/360/kvm switch/hacked joysticks  (Read 1891 times)
MAME TIME
  • Last login:March 23, 2019, 10:23:19 pm
« on: December 05, 2011, 05:08:37 pm »
hey Guys i need some help im at the end of my build but this last configuration is holding me back, have a mk4 cab with a xbox360 and a mame pc, i have a kvm switch to go back and forth between them and im using 2 hacked street fighter 4 pads(USB) which are identical, my problem is how do i get the pc to have pad1 as player 1 and pad2 as player2, because when i reboot the pc or switch to the 360 and back pad1 at times will be detected as player 2 and vice versa, im trying xpadder and joy2key, maybe im missing something, is there a way to set 1 pad as a primary?? any help will be great thanks
Too Much Game, check out my ish!!!
Geometry Arcade
Neo Geo 360
MK2 standup
SF2 champ edition X2
Donkbaca
    • Slim built MAME/Xbox cab
Re: Help!!! pc/360/kvm switch/hacked joysticks
« Reply #1 on: December 05, 2011, 05:25:56 pm »
in windows xp, go to control panel, controllers, click on the 1p pad and then click on "make this the preferred device"  It will always be player one.
MAME TIME
« Reply #2 on: December 05, 2011, 05:37:30 pm »
so regardless of powering down or switching throught the kvm, pad1 will allways be primary?? Donkbaca are you using joy2key or xpander?
Geometry Arcade
Neo Geo 360
MK2 standup
Donkbaca
« Reply #3 on: December 05, 2011, 06:59:04 pm »
Yup
Neither.  I am focusing on MAME at the moment, and MAME recognizes the joypads as joysticks, and when I use my console emus, I use other xbox 360 pads and have it all set up through gameex
MAME TIME
« Reply #4 on: December 06, 2011, 03:35:29 pm »
i set the default on pad1 as the primary but after turing the pc of or using the kvm im getting the same result, both are switching up,
Geometry Arcade
Neo Geo 360
MK2 standup
MAME TIME
« Reply #5 on: December 06, 2011, 04:58:43 pm »
hmmmm i just staged another pc with the kvm and 2 xbox wired controllers and its works as it should, maybe a driver issue on the other terminal, im sure it shouldn't be any different with the street fighter 4 fight pads compared to the 360's
Geometry Arcade
Neo Geo 360
MK2 standup
Donkbaca
« Reply #6 on: December 06, 2011, 05:22:54 pm »
i use the wired sfiv pads, and don't have that issue.  I just went into the control panel like I said, and it works fine.
