Author Topic: Altering the transparency of the MAME in game menu screen??  (Read 1938 times)
lettuce
  • Make It So!
« on: November 29, 2011, 09:29:20 am »
Is there a way to change the transparency of the MAME menu when playing a game?. Im trying to setup HLSL but the menu is covering up most of the game screen, is there a way the transparency can be change so i can see the gaming screen?
nexusmtz
  • Last login:June 10, 2026, 11:25:24 pm
Re: Altering the transparency of the MAME in game menu screen??
« Reply #1 on: December 03, 2011, 01:49:08 am »
I can't help you with transparency, but 'covering up most of the game screen' suggests that you're using the config menu instead of the on screen display.
If you haven't changed the mapping, ` (backtick, usually next to the 1 key) will toggle the on screen display. That allows you to adjust one slider setting at a time.
I don't know the reasoning behind this, but the on screen display is context sensitive. If you bring it up in-game, you can adjust the volume and most of the HLSL settings. However, if you toggle it while you're in the Slider Controls menu (where it's already visible anyway) you can adjust all of the sliders that appear in that menu without the menu itself being in the way.
The Slider Controls menu doesn't expose all of the HLSL settings, but it's a start.
--Nexusmtz
