Author Topic: weird speed problem with area51  (Read 1451 times)
Lilwolf
  • Last login:June 08, 2026, 09:58:06 am
« on: November 19, 2011, 12:42:04 pm »
I'm getting really slow frames on area51 with topgun installed (didn't notice it until then).  weird thing is that if I hit ins, it gets to over 1000% and runs super fast.  I tried everything in the ini file I can think (remove the lightgun, and video stuff... )  No wait for framerate or anything.
it shows as 100% frame rate...
any clue?  btw, I'm running 144 downloaded from mamedev so it shouldn't be a compile issue.
Also, I tried on my main machine and it works there...
Any ideas?
Hoopz
  • Last login:June 09, 2026, 10:42:21 am
  • Intellivision Rocks!
Re: weird speed problem with area51
« Reply #1 on: November 19, 2011, 12:47:03 pm »
Did you change any sound settings in mame.ini?  Onboard sound or separate card?  I'd fiddle with those settings too to see if it help.
Lilwolf
« Reply #2 on: November 20, 2011, 05:41:47 pm »
nope...
and again... I'm showing 100% and if I press ins, it runs faster then needed....
